I can't play downloaded neural captures(Quad Cortex)
Hi,
I have downloaded some neural caputers via iPhone app and I let the list appear in my Quad Cortex.
But whenever I select them, my Quad Cortex plays previous preset so I can’t use the captures now.
The os is up to date.
I need help for solving this issue.
Thanks in advance.
Your question seems to indicate that you misunderstood what a capture is. You seems to expect that selecting a capture will replace the currently selected preset.
This is not the case : a preset is merely a bunch a block you selected and placed on the grid, and tweaked to your liking. A capture is one of those blocks.
So : create a new preset (the grid will be empty, btw: check the ‘input’ and ‘output’ sections), go to the ‘neural captures’ group (in Cortex Control, it is on the left) , expand the ‘downloaded’ section (or any section were you put the downloaded capture) and drag and drop the capture onto the grid (central section of the screen).
Sorry if you already know that, and if the problem is elsewhere :upside_down_face:
Hi,
I did as you taught and could make it!!!
Now I understood how it works.
I really appreciate with your support :grinning_face:
Great ! At first the QC could seems to be complicated, but the manual is a must read if you really want to get its full potential !
Heres is the direct link to the most recent version : https://downloads.neuraldsp.com/file/quad-cortex/Quad%20Cortex%20User%20Manual%20v3.2.0.pdf
I read it several times since I bought my QC (December 2021 ! A lot of things have changed since this version !)
In case you want to download a future version , simply go to Downloads - Neural DSP and under the ‘Quad Cortex’ section, there’s a ‘Manual’ button that gives you access to the most recent manual !
I agree that I should read the manual for full use and I will.
I feel lucky I got to know about this wonderful machine!!!
Thank you so much :slightly_smiling_face:
