Hey all I am trying to run this setup to my Princeton reverb tube amp and also front of house. I am lost on the sauce. Any help is much appreciated. I want all the effects pre and post to go to both FOH and to my real Princeton Reverb. Ideally would like to have the amp/cab only running to front of house. Every time I try to split it doesn’t do what I want. HELP!
To understand a bit better, it appears in your preset you are sending the signal with cab to multi-out which would send to both FOH and your amp. Typically, you would send one signal chain to FOH using the cab block probably via XLR outs 1/2 and likely use output 3/4 direct to your amp without the cab block. At least I believe that is what you are looking for?
Yes. Do I need to face two instances of each effect, on September rows? And can I just use one looper for both?
I finally got them split. Thanks.
Last question is there a way to share the looper with both lines? Or both outputs? But one not having the amp/cab sim ?
good question about the looper. I know there are settings to dis-associate it from the grid so it just loops the outputs but I don’t think it can record two separate tracks for different outputs. I might have to try this setup out and see
