How to use transpose dry signal?
Hello all!
So, I’m looking to record wet/dry signal, but I need my dry signal to be transposed too. I’m using a low tuning and I don’t have the proper bass guitar to handle the tuning.
I’m using my QC as an interface with GarageBand.
Thanks!
@xush, is this another problem solved by the Transparent Blend block?
Thanks!
I’m looking to have two separate tracks to use for someone else to mix that probably doesn’t have access to QC. Could I re-amp the dry track with a transpose block?
Yeah, you can totally do that.
I was referring to another forum buddy who pops in with surprisingly creative uses for a different block type.
Do you know of a way without re-amping?
thanks again!
thanks DC!
I’ll have to experiment with that a bit-
@Promo - how are you recording this? Via USB into a DAW, or thru an external interface?
Also if we could see your grid it’d be easier to advise
I think I have it all ironed out guys. Thanks so much for your help!
