Hello~
How do you guys set up your quad cortex?
Put a gain module in the chain where you like it (beginning, end etc.) and set it to be controlled by one of the 2 expression pedal options. Note that the gain module goes from -60dB which means some leak if you use it early in a high gain chain.
Hi there,
I had the same issue and came up with this solution.
In the Utility section pick “Gain” and place it wherever you desire in you chain. I placed it right at the beginning of mine. Then assign an expression pedal to it.
Do you know how to assign one?
Best regards
Peavey
Thank you Peavey~ It works. great~
Thanks~ hasse
We really need a volume block where we can set the max volume to be 0db and not boost level. In all the work around currently I have to limit the max part of sweep to it ends at 0db and not +xyz db
So as a temporary measure, I use EQ block with didn’t regulate parameters. I placed it before delay and reverb blocks. It works pretty well like a volume pedal.
Plus one for this, i used the eq block and assigned the pedal to the output volune on page 2, setting the max at 0db. Personally i’d like a dedicated block that also enables the tuner when exp is rocked back and fully off.
