Friends. I can’t figure out how to send out MIDI messages (PC) on scene change. There is a setting in the menu, but it’s only about Preset changes. I need to send midi on scene change. Thank you very much in advance.
if you go to the preset
there you can select the 3 dots…scroll all above and you will see midi options
PRESET MIDI OUT…
There are 2 options…
- run midi commands during selecting of the preset
- If you select in the menu for example footswitch A, you can dd midi command to execute when yo uselect the scene corresponding to the footswitch.
So for scene mode you can run 1 command (CC, CC toggle or PC)
Ah! Great, thanks a lot, it worked! I didn’t understand how Preset midi out works, now it makes sense.
