I tried creating two separate rows and choose out 3 for one and out 4 for the other and tried panning the cabs, but it doesn’t seem to work. When I pan I only get sound from the left speaker. What am I missing here?
I also asked the same question on reddit, but so far I have found only one solution, which doesn’t seem very ideal to me.
So my scarlett is 2nd generation, which means there’s no mixcontrol app or mono/stereo direct monitor option.
What worked so far is to use DAW, create two stereo audio tracks (that gets sound from both out3 and out4 from qc) , and then create 2 separate lines on QC with different amps and cabs and delays etc… and then I hard pan one channel to the left and the other to the right. And now I am able to hear different tones and effects separately. But there must be a better way. I mean, if I want to use only one amp and stereo delay. Now what am I gonna do? Create two rows again with identical amps and cabs, but only change the delay settings on them?
By the way all my cables are TS. Do I have to use TRS at some point? That I also don’t know.
That’s all you can do based on the limitations of your audio interface. My MOTU M4 has the same issue, no pan knob or dedicated software to change the panning. So, it has to be done via DAW.
However, on my second room I have the UA Apollo X4, which allows me to pan via UA Console software with no latency. In that case, I do not need to use my DAW.
