Hotone Controller+Exp Pedal+NC doesn't works
I use My NC with a Hotone Press 2 plug in Hotone Midi Controller.
This configuration doesn’t works.
When I assign Expression Pedal in Ctrl 1 of the controller on CC#1, on position 0 (heel) to position 127 (toe) for example, the wha doesn’t works.
Yet, it turns on or turns off my slot number 4, I don’t understand.
I have same issue with the morningstar MC6PRO. I use the wave generator which normally sends CC#1 from 0-127 to the Nano Cortex, but the crybaby wah on NC doesn’t do anything.
Did you change in the app from midi to expression pedal, assign it and change back to midi?
Yes I did… It seems like the NC doesn’t act on the cc#1 commands via midi.
I dont use the expression/midi inout btw. All goed via usb- connection
