Headphone recommendations for QC?
Hello guys,
I’m used to playing my QC through a BOSE S1 Pro (plugged into headphone jack on QC and 3.5mm input on PA) and really like the way it sounds, but recently moved into an apartment with very thin walls. In an effort to keep from disturbing my new neighbors, I tried my pair of Beyerdynamic DT770 PRO (80 ohm) headphones last night and really did not like the way they sounded. It felt like they were squashing the audio, and it ended up sounding muffled, tinny, and pretty dead. I’m looking to get a different pair of headphones for use with the QC, can someone please recommend me a pair? I’ve done quite a bit of research and saw many, many recommendations, so I’m sort of sitting with analysis paralysis right now. I’d like to just plug into the headphone jack on the QC and not need to fiddle with EQ or settings as much as possible. So far, I’ve seen recommendations for AKG Pro Audio K371 and Beyerdynamic MMX 300 while researching, and I’d really appreciate some additional input before I go and spend any money. It would be great if they were less than $300, though I could be persuaded to spend more since headphones will likely become my main mode of practicing/playing at home.
Thank you!
Hi @Aideux, there are already quite a few threads featuring QC users’ experiences with headphones. Check these out:
Maybe some open back cans like the DT990. They’re on sale DT 990 PRO: Open studio monitoring headphones | beyerdynamic
Hi I use AKG Q701 Quincy Jones. The problem I have with these is that they sound too good. When I record I have to add som sharpness to the sound to fit in the mix. But this is a minor problem.
It’s nice to have headphones that sits soft and sound nice. Other problems could be adjusted.
D
I had the DT770 and 990’s then tried the AT’s and couldn’t be happier! https://www.sweetwater.com/store/detail/ATHM50x--audio-technica-ath-m50x-closed-back-studio-monitoring-headphones
I second the ATH-M50x. I quit looking after getting a pair of these.
I’m very late to this conversation! But are these the 38ohm ATH-M50x? Do they still work well? Iown a pair and I’ve ordered a quad cortex but was thinking these headphones might need to be changed?
I’m still using the 38 ohm ATX- m50x. They still sound awesome to me!
Agreed! They are my primary headphones in use now.
Guys that’s so helpful. I was about to pull the trigger on selling my ath-m50x headphones to buy some dt990’s. I read another thread saying the ath-m50x distorted, but I’ve used them loads off of a strymon iridium. Really appreciate the advice !!
