It’s only overdriven tones that are sounding bad. That’s with humbucker as, P90s and single coils.
I use Lollar P90s in my Bilt Volare, they sound fine thru my QC.
Did you adjust the impedance on your I/O settings? What effect does that have for you?
You should also try lowering your input level in that swipe-down main I/O menu, just to compare the overall difference in tonality/signal level. Apologies if you’ve done all this already
What way are you all setting the global eq?
I did a proper factory reset on my QC and it appears to have cured this issue!
