I’m on trial with Gojira right now and the UI when used within Reaper does not scale properly. Both Nolly and Cory Wong, which I own, works flawlessly.
Please send an email to support@neuraldsp.com thank you
Hi , I have this problem too in Reaper with my monitor tuned in 4k , that works at 1920x1080p i have my full window with Gojira whole i can use in Reaper but with 4k the window is horrible , as standalone mode in 4k that works nice but not in Reaper , there is something to do in Reaper that i don’t know how to do
GOJIRA UI displayed huge!!! This is also present in FLStudio.
WORKAROUND is to use 1080 resolution or change scale settings (Ex. 100%) if you are using 4k (not so convienient because you will see all your workstation too small).
Better solution would be a fix by developers.
