As a producer, I find it incredibly useful to record a DI signal into my DAW, and “reamp” it with the Quad Cortex later (looping the audio and auditioning presets to find the perfect sound).
To do that, the DI signal must be sent from the DAW to USB Output 5 to 8 (which will then be the Input on the Quad Cortex).
However, Inputs on Quad Cortex’s factory presets are all assigned to Analog Input 1. Whenever I audition a new preset, I must manually change the preset’s Input to USB 5.
Although manually changing the input “gets the job done”, a “global input” or “lock input” feature would be a HUGE time saver when reamping / scrolling through presets.
Since the Quad Cortex has a global Cab Bypass feature, a Global Input Lock should also be feasible, and it would be an incredible “quality of life” improvement.
Thank you for listening, Neural DSP ![]()
