So i just got the QC with an FRFR speaker.
Already made some nice presets and learned about Global EQ being able to make your FRFR speaker sound more “natural”.
Now I’m noticing the global EQ also effects the sound I play from my PC through the cortex with USB. Is there any way to bypass this? In other words, keep the audio coming through USB from being affected by the global EQ?
The Global EQ can be assigned to either Out 1/2, Out
3/4, or both pair of outputs.
I have 1 FRFR speaker. Connected via output 1.Usb output also goes through output 1 to the speaker.
If play music from usb and guitar they both go through the global EQ. I don’t see any point in making USB go through it. But doesn’t seem like any way around it.
It would be tedious if you switch between a lot of presets but you could add an eq block in your signal chain and turn off the global eq.
