Gapless switching between different amps - Scene Mode - Quad Mini
Just playing around with my Cortex Mini, and I can’t get Scene mode to work how I want it to. I saw in an Ola Englund video that he had a different amp on every single line and switching between them with the foot switches so that he has gapless switching.
I can’t seem to get this to work. I got a Roland Jazz Chorus set up to A (apparently) and B should be an EVH, but I can’t get them to switch for the life of me.
Even with A all turned off, and B all turned on and assigned, it still doesn’t switch.
Any ideas?
Ive also tried changing the Scene block bypass behaviour but that doesn’t seem to do anything.
I know it’s an old video, but how did Ola get it to work like this? https://www.youtube.com/watch?v=Ps8Oj_-GBZs
First things first:
You have Scenes set up correctly, right? Go into each amp block and make sure the ‘ABCD’ icon is activated over the on/off switch. Then you have to go through each Scene and make sure the amp block is set the way you want. Do this for both amp blocks, and for everything else that is Scene-activated.
Even if an amp block and cab block are disabled, there is still raw audio going through the row, which can be fed straight to Multi-Out if you’re using that. In that case there would be unprocessed guitar now being blended with the processed amp signal you’re trying to use. And that brings me to my next point…
A word of caution:
This Ola video pops up from time to time. I have posted extensively about why I think the one-amp-and-cab-per-row method is a bad optimization for Scene mode. Takes up an unnecessary amount of grid space, and it’s really easy to make mistakes.
My recommendation is to place all of your amps together on a single row and switch between them.
If you still want to do the one-amp-and-cab-per-row method, go ahead and share your preset. Someone here can figure it out.
when you assign the Bypass to Scenes, all scenes will still have that block in the same state until you change them individually. Could it be that you forgot to invert one of the power/bypass/on-off buttons in one of the other scenes? That’s pretty common
