Gain Trim on captures before saving
Would love if possible to just have an ability to slightly bump up a bit of gain when making a capture. The Neural Captures seem to my ear to be slightly less gainy than the source (this is across the board from edge of breakup to heavier tones). I appreciate the gain added post capture can be done within the actual block but you can’t do this until you save the capture (would be handy to do it whilst comparing capture to source). Also appreciate that the gain that will be added is different to the gain within the pedal/amp but the difference is so minor I don’t believe it would matter all that much.
I found when making captures of high gain amps, I have my input volume at 3db and when I capture clean amps I have it a 0 db. So far that has worked out pretty well.
