Fuzz pedal into amp's clean channel
I’m considering the Quad Cortex and have a question about replicating something I do IRL.
I sometimes put a pedal(s) into the clean channel of an amp, if I want the sound of the pedal (like a Big Muff) roaring through my cabs. Or maybe through the fx loop depending on the pedal or amp.
I thought there would be some kind of input/channel selector in the UI for each amp and haven’t seen that, but I’m looking at the device list, and I guess there are only certain amps that are separately available as clean?
For example, if I want an Orange Thunderverb or a Dual Rectifier, there is no clean amp for these. Usually bringing the gain fully down on an amp isn’t the same, but not sure how it works in this.
Do you just try and pick whatever’s closest?
