FRFR Connection
Just want to confirm, when using just one FrFr cab, i use the 3L output on my QC ?
Depends on what you set as output in your preset (tap the output block). You can use Out 1-4 and even the sends.
David is right. You just assign wichever of the six available outputs you want to use at the end of the lane that will feed your FRFR.
Thanks so much, been busy with a massive IT project……good to play my guitars again
Thanks so much , will continue with purchase
Thanks so much, cannot wait to purchase
Happy to help! Although the QC is still a bit of a “work in progress”, it sounds fantastic and the UI makes it a pleasure to program. I think you’re going to be happy you bought one. Welcome to the family.
Thanks once again, looking forward to spending some time with my guitar this week-end
