CorOS Version: 3.1.0.
When I put all the items from nameless plugin to a row, and put a wah too, the sound muted, and have to restart the device.
Doesn’t the default patch have all the blocks? Are you able to repeat this consistently or does it happen intermittently? If it’s repeatable, definitely reach out to support…
All default, the cab is the Mono version.
Jase via Neural DSP <notifications@neuraldsp.discoursemail.com> (időpont: 2024. dec. 4., Sze, 20:40) ezt írta:
Looks like maybe you have too much for one DSP chip. Maybe spread it out over a couple lines; put a few of those blocks on the 3rd row. See if that fixes it. You may just be overloading it, which can cause crashes.
By “default”, I meant the default preset, which has all the blocks, but they’re spread out over a couple chips. That’s probably the issue.
Its interesting, if I drop the icons different sequence, there is no problem
My sequence is:
Zoolo, wah, Frontin grind, hexdrive, Fortin amp, Nameless mono cab, Nameless delay, nameless reverb
Jase via Neural DSP <notifications@neuraldsp.discoursemail.com> (időpont: 2024. dec. 4., Sze, 21:27) ezt írta:
