[3.0.0] – November 29th 2019 – To ensure a setup without problems, we recommend to make a clean install of this software. Please uninstall the previous version before installing this update.
Added
– AUTO DEMO was implemented. Trials no longer need an activation code to be activated.
– BUILT-IN TUNER is now available in both versions, plug-in and standalone.
– The standalone version received MIDI SUPPORT. Now you can assign MIDI commands to control plug-in parameters, UI components, and presets files.
Changed
– STEREO MODE #1: Stereo Switch now pans the microphones internally as dual instance.
– STEREO MODE #2: To ensure retro-compatibility with old audio sessions, we didn’t add volume compensation when you turn on both microphones at the cab section.
– ZUUL algorithm was redesigned to be more accurate to the physical unit.
Fixed
– Multiple bugs are now fixed to improve stability, graphic performance, and audio issues.
If you experience any bugs, errors or crashes, please contact our support team at support@neuraldsp.com.
