Focusrite Scarlett 2i2 - Only recording DI Signal
@ianrockett1988 The performance will depend on your hardware and how optimized your system is. First, try to replicate these settings in Reason (Edit > Preferences > Audio):
  • Audio card driver: ASIO Focusrite USB ASIO
  • Sample rate: 44.1000 Hz
  • Buffer size: 128 or 256 samples
After that, take a look at our guide for PC optimization: Optimizing your PC for Music Production
Finally, analyze your system using Latencymon (https://www.resplendence.com/latencymon). DPC latency can cause several audio dropouts due to drivers or hardware issues and is usually not measured by CPU usage.
If nothing works, then you may need to upgrade your hardware.
I hope it helps!
