Feature Request: VST Effects Loop
Thanks for the incredible plugins guys. I own so many and love them all. Because of how many I own, I am interested in experimenting with various 3rd party effects placed in the signal chain at various locations. For the effects that should come before the amp, this is no problem. But when I’d like to get into the Effects Loop, the only way I imagine I could do this is with two instances of the same Neural DSP plugin, with the amp turned on, cab off on the first instance and vice versa on the second, inserting the effects I want to place in the “effects loop” between the two instances.
First of all, is my workaround legit with your software design? This would effectively model a real effects loop? Secondly, will you please release some updates that would make such a use case more resource efficient and optimized for all of your plugins? Considering the Quad Cortex has something like this, I would imagine that you could port the feature to your VSTs?
Thanks!
