Expression/MIDI via TRS
Cortex cloud app doesn’t show an option to assign expression pedal when Exp/MIDI is set to receive MIDI messages via TRS, even though there is expression pedal configured and connected to midi controller.
It would be much nicer user experience to be able to assign expression pedal to control whatever function irrelevant of what the EXP/MIDI input is configured to..
I think this is more of a Cortex Cloud App bug fix since expression over midi is possible and TRS is no longer the only option for expression pedal input
if you set up the expression pedal and then switch the selection of the TRS to midi, the expression pedal works as configured
A simple fix would be to not hide the expression pedal configuration in the cortex cloud app.
No NanoOS update required!
Yes, exactly, unhiding expression pedal settings would help. Switching the input from exp to midi is just uncomfortable hassle
