Explicit midi toggle function
Most of the midi controls are working as expected except for the toggle functions like gig view and tuner on/off. I would like to see a midi implementation where a value between 0 and 63 means tuner off and 64 127 means tuner on. In corOS 1.3.4 every CC#45 inverts the tuner state. The value of the message doesn’t matter.
In my case, I want to program a full set in a daw including preset changes, modulation and tuner on/off between the song. It’s not helpful in a live scenario when I turn on the tuner manually that the next midi message (which is programmed to turn the tuner on) turns the tuner off.
@M_NDSP I’m glad to see that this feature is implemented since version 2.1.0 :slight_smile: This thread can be closed
