Doubler Question
When using the Doubler in a stereo setup is the spread only coming out of Out 2 if using the XLR outputs? Or it mixed into both outputs?
If I understand it correctly one side output 1 would be the original signal and the other the delayed one, so yes.
If the delayed and original were in both outputs you would still have a mono signal and some phasing.
