Hi QC community! Anyone has any guidance in setting properly dotted eight delay with QC?
I don’t see how to input the tempo, any link to online resources/ presets?
thanks
thanks
All the Delays have a tempo sync switch, turn it on and set the delay interval (sync note) to 1/8D (that is a dotted eighth. As for “tempo”, tap the 3 dots in the top right to get to the tempo menu or tap it in with the tap tempo switch and then adjust the value manually as required. This can be set globally, per scene or per preset.
At this time, Modulations are not time syncable, hopefully this is something that will be introduced because it’s sadly lacking…
