Can I just check if this is normal since updating to CorOS3.0?
On startup, my QC no longer immediately shows the loading screen. All the footswitches flash together 5 times (on / off) over the course of about 15 seconds.
The device then appears to turn off completely for a couple of seconds.
It then switches itself back on, and begins the “normal” start up process that I used to see immediately before I upgraded the OS.
That then takes nearly a minute to load, with the loading bar displayed.
This means since updating that the whole process takes about 70 seconds to go from turning on to being usable, which is a lot longer than it did before updating.
When I updated, I had problems, and was left with a device that would not switch on at all. It took a lot of on / off / leaving it overnight to get it working again and then I had to run the update a second time. Since then it’s displayed this behaviour.
Is anyone else seeing that? Or do your units just go straight to the loading screen now?
Thanks.
