Distorted sound on clean preset
Using Cory Wong presets live . Master volume 100. After an 1.5 hr set sound begins to distort. QC is cool its getting plenty ventilation. Using other clean presets in banks 1-4 similar issue. Its difficult to play any 70’s funk or disco with any distortion thru monitors IEM or wedges. Same with 80’s pop lie Prince, Cameo, The Time etc. Why is this happening in both of my QC? I have the latest update. And in the Cory Wong preset when Dist Pedal is turned on in stomp mode volume and sustain drops
Are you using the factory power supply?
Distortion is audible from every monitoring source?
Never heard of this happening.
Did they model the tubes TOO WELL?!
xush mentioned everything which comes first in mind.
Do you really mean distortion?
Maybe the leveling on the mixer isn’t correctly set up?
Are your I/O settings legit?
Have you tried another presets (maybe in rehearsal) where this happens? (with another captures/models)
Are you using an active guitar, a battery powered pedal or wireless before the QC, that may have a week battery? Having the same issue with two QCs seems highly unlikely. Also, if you have a multimeter or voltage tester, can you test the voltage at the outlet to make sure you don’t have a low voltage issue.
