I frequently use an expression pedal assigned to the frequency parameter of the Hi/Low Cut EQ Block to create a synth like cut-off filter effect (In my case low-pass, as I’m a bass player).
This works very well, apart the from the fact that there is some lag when I stomp down on my EXP pedal for an immediate cut-off. NDSP support explained this was due to smoothing they programmed on the sweep of the frequency parameter.
It would be fantastic to make this smoothing feature optional.
Thanks!
