Disable cab in captures with cab
Maybe there is a solution to reduce cab influence of the capture so we could use our ir block with the captures like that
One of the big features of the Kemper. However there are a lot of captures on the cloud with no cab. You should find something you need on there.
the kemper cab off is really cool tho
Meh. I´ve heard it doesn´t work too well in the Kemper. It´s still a non-solved feature, it would take a lot of development time to get a decent result. Probably several years.
was good enough for me tho
