Would there be any reason that I would constantly have a steady DI signal sound alongside the processed sound? Currently using the Steinberg UR-RT2 I/O with Cubase Elements 10.5. I/O settings are correct in the plug-in/stand alone. Only input 1 is selected. DI signal still comes through tuner when muted.
Hi @prsboogie2. You probably need to disable Direct Monitoring on your interface.
Here’s a thread describing how to do it: UR-RT2 Direct Monitoring
Thank you for your response! I overlooked direct monitoring and that corrects the issue within the DAW. However I’m still having the same issue when I use Plini as a stand-alone.
Thanks!
I believe I’ve got it now, thanks again!
@prsboogie2 You’re welcome!
