From Allow footswitch assignment when using "Set parameters as default" :
The post mentionned above was about the Footswitch default assignement (which is a bad thing , imho) , the discussion led to:
- By default a block shouldn’t have any footswitch assigned.
- Any block should have the ability to have multiple user-defined ‘configurations’ (in addition to the ‘Factory configuration’ that would be read-only, in case we want to restore the initial default)
- The User-Defined configurations should store the whole block settings, including the Footswitch assignement.
So, if the ‘block user-preset’ (aka 'block user-defined configuration’) become a reality, I hope that they will take this into consideration, as it would solve two issues in one feature !
