Cortex Control Troubleshooting
I’m seeing a LOT of reports of issues with Cortex Control, so I’ve compiled as much of the pertinent info from this forum on this thread. Please add any observations or solutions you have found.
In some cases, users have reported Support says their issues are due to hardware failure and their units had to be sent in for repair/replacement. Be sure to check w/ Support@NeuralDSP while you’re troubleshooting.
cortex crash reasons;
non-powered hub/dock
multi-monitor setup
too much USB traffic
version mismatch w/ CorOS
bad USB cable
reinstall CoCO
backup/reset/restore QC CorOS
hardware failure, unit requires repair
Here is information from users as to what has helped in their cases:
if I turn on a VPN, the settings open just fine.
However, my account does not display, and I can’t access anything on the cloud, which is probably a result of the VPN itself. Of course, I can access this forum and the Neural websites, but it doesn’t translate to the Control app or the QC getting any information. I can be connected to WiFi on the QC, and the Control app says I’m using the computer’s internet connection, but it has no device account link info at all. But the settings do open and the app doesn’t crash. So it’s something to do with the account settings/link or the internet connection calling that up and failing.
A lot of people have connection problems using some kind of USB dongle, hub, dock, etc. Including myself. Try using a direct connection trough a single cable. Using a USB B to USB C cable connected directly to the QC and my MacBook air m2 fixed my glitchy cortex control connection. Works like a charm now
I was previously using the provided USB-B to USB-A cable alone with an Apple dongle to my M1 MacBook Pro. It would get stuck “Loading Presets”.
I read that a USB-B to C cable would work, and I ordered one. Strangely it works, but only 1 orientation. Sometimes I have to flip the cable around (so much for that reversible connector promise).
Then I found if I had any of my thunderbolt hubs connected (which I use for my external displays, Apollo interface, keyboard/mouse, etc) then it would crash. The QC would still be connected directly. Just the mere presence of another hub seemed to cause issues.
I have identified what happens on both my Macs.
The issue is present only when my BenQ BL 2420-T monitor is plugged in. It doesn’t matter if it is using USB-C (to DisplayPort) or HDMI. The second I plug the cable, the USB connection starts to reset very often, leading to audio drop out, and USBAudioTxFrameSkipped and USBAudioStreamingEPEnabled values start to increase.
The second I unplug the cable, those values stay idle, the USB connection doesn’t reset anymore and audio work perfectly fine.Even if I switch the monitor off using the physical switch behind, if I plug the cable in, USB is screwed.
The only way to be able to plug the cable in without having this glitch is to physically unplug the power cable of the monitor. It is a 3 wires grounded power cable (IEC-C13), so…could it be a ground loop, or a grounding problem to which the QC would be overly sensitive? My Scarlett 2i2 never complained
I’ve had sporadic crashes, but after updating to 1.1.1 it’s crashing every single time on startup. This happens even if the QC isn’t powered on. I ended up getting CC to start by uninstalling and then re-installing it.
new report re: PSU causing issues:
from user “Jamsden”
I was having trouble with Cortex Control becoming unresponsive to UI events and crashing on macOS. But I found the issue was with an off-brand 12v power supply I was using. QC runs fine, but I suspect the power supply was injecting noise into the USB cable causing the issues. When using the power supply supplied with QC, Cortex Control works fine, no crashing at all. So check your power supply.
if CoCo won’t make local backups on Mac:
“take it off the full disk access list, clean uninstall with app cleaner and then reinstall.”
@jamsden Which power supply was causing problems for you? Might have just been one faulty one but I would prefer to avoid it.
CC runs great on my studio computer but at practice on my laptop it is slow and takes time between changes and its really annoying. The laptop runs the Fractal editor just fine and its not a slow laptop. IDK
