Cortex control after sleep/hibernation
Every time I reactivate my pc (win11) after sleep/hibernation, cortex control does not recognise the QC.
I have to close and reopen the app.
Is there a solution ? Thanks
Are you by chance using a USB hub? If so, is it powered? I have seen using various hubs can lead to that behavior.
no, directly to the motherboard usb ports
I’m running W11 as well with no issues though and haven’t seen much about this issue you are having. I assume you have the current USB driver and Cortex Control installed? Worst case, email support@neuraldsp.com so they can log your issue and help provide resolution.
