Constant Mini-Tuner
I’ve been hooked on the QC for two weeks now and in the meantime I’ve sold both my Axe-FX III and my FM3.
The only thing I miss is the constant little mini-tuner that is visible all of the time on the Fractal units, I wonder if it’s possible to integrate something similar without breaching any copyrights!
Thanks!
Surprised I haven’t seen a request for this yet! Voted!
Oh, that’s a good one! Voted!
Hi @VanDaven
Good idea, tho I’m not gonna vote just yet, sorry, 'cause I’ve spend too many of my designated votes already :sweat_smile:.
Being constantly reminded of tuning is probably not my idea of staying in tune, would rather rely on basses that are stable.
Bless
I could imagine this going in the same visual location as the CPU monitor. And there’s certainly room, it doesn’t have to be any more fancy visually than a headstock tuner, which about half a square inch of display.
I absolutely want this.
It could be a just another device block on the grid that would show the note name you are playing and a super simple in-tune/out-of-tune color indication. Maybe even user configured parameter that determines what range “in-tune” is.
brilliant. I’m used to having a tuner out to an always on tuner but this certainly takes the cake (if its low DSP).
Yes! Definitely want an ‘always on’ tuner option, no matter how small :slight_smile: Sometimes you just want to check a note without having to long-press the tuner button and kill output. Maybe it’s not for everyone, so it could be a feature toggled on/off from the tuner window…I’m sure there’s room for a mini tuner somewhere between the preset name and upper right menu buttons?
A feature like this would add some overhead, even if it was negligible. Therefore, as others have pointed out, it should be a global on/off option. Also, much like the global EQ, it would have to get the greyed-out symbol when you switched to a preset without adequate DSP available (probably the DSP allotted to the first two paths as it is their DSP that tends to be used for these kinds of functions).
Absolutely! Saves rigging up an entirely separate through tuner every time
resolved?
There’s a rudimentary Always-On tuner in Gig View now since 3.2
Doesn’t tell you what note it is though! Not very helpful if you need to quickly go to drop D between songs.
