Changing the new Deluxe model in scenes
Cool thing about the new Deluxe model is that you can choose between the normal channel, the Vibrato Channel and the Bright Vibrato channel. However I can’t find a way to do this in scenes. Is it possible?
Best route would be to have two amp blocks in the preset and switch between those with scenes
Does it not work to tap/hold it to bring up the scene link option? May be worth putting in an email to support…
Mine assigns with a right-click thru CoCo, but can’t on the QC itself. Feels like a bug worth reporting
That’s odd. I just tried it with a new preset with only the Deluxe 64 and 65 and was able to scene assign the mode switch on the QC as well.
I just did a long tap/hold on the selection box and the scene icon appeared.
Maybe the “sweet-spot” is harder to find on the QC, I’ll try again
I was pushing and holding on the wrong thing. I was tapping on “mode.” The correct thing is to tap on the actual rectangle that says “Vibrato” “Normal” etc.
Now it works just fine.
Thanks everybody!
