Changing Expression Pedal behavior? (Latch Simulation)
When I use my Expression Pedal (M-Audio EX-P) I use the Latch Simulation to turn on / off effects. The only problem is, that it happens when my foot is on the heel. Is there a way to change it to Toe position?
There’s a button next to the Dropdown on the Expression Settings Menu, if you click it, it will revert the heel/toe activation. ( i think it was the “invert range” button or something)
I’ve tried it but it doesn’t work. The switch only turn on / off the effects. But still the expression pedal will react when I’m in Heel position.
have you flipped the polarity switch on the bottom of the pedal?
Yes, I also tried that. The expression pedal works fine for the rest, just the toggle behaves on the heel position is the “problem”.
Are you trying to use a toe-switch to toggle an effect’s bypass state?
