Change Key - for any/all Plugins in a Preset (or Maybe Even a Bank)
Hi,
WITHOUT MANUALLY going into a specific fx block (like the mini voiceeor any fx block) - is there a way to change the key?
I have a preset created, but I do NOT know ahead of time what key I will be playing. I “sit in” with other bands /musicians and they call the shots. I typically use SCENE MODE - and I do not want to have to exit out of the scene block/listing, find the specific fx block or blocks, and have to open them up to change the root. Way, way, way, way too much work.
I also - DO NOT - want to reproduce my preset in 8 different keys (roots) so I can more easily switch between them.
I GET IT….. on a rare occasion there are songs that are not in a single key, or they modulate at the end or something….. but most of what I play stays in a steady key for the song.
SoooooOOOOOooo… is there are “key” setup or in the settings, that would - WITHIN A PRESET - change the key through a footswitch - WITHOUT MANUALLY opening up any of the applicable fx block, and changing the key /root?
BONUS QUESTION: If I am in scene mode, is there a footswitch or footswitch combination that can close the scene (block) listing screen; or mimic the swipe up motion to show the preset signal path and fx blocks?
Thanks
AJ
I suppose you could assign the note parameter to a expression pedal and « sweep » through the keys.
Never tried that though.
