Hello,
(Hopefully not already posted)
I would need to have MIDI CC#7 implemented as a global volume with a menu allowing setting the on/off feature and min/max setting per output (pair of outputs).
This allows to use a midi controller (BOSS EV-1-WL and/or DAW or any other MIDI source) to control global volume during a live performance independently of and patch/scene.
Using MIDI Cc#7 is standard and it doesn’t block one of the 2 expression pedals, as well as allowing 1 controller to control all outputs simultaneously albeit with a setting for each : set different ceiling max vol limit per output allows a specific min/max volume per output type (typically max 0dB at XLRs for mixers & PA, same for USB for sound cards & DAW and a max volume that can be set differently for jack outputs that drive my Headrush stage monitors).
Thanks !
