Has anyone found a paddes case, or gig bag that is a reasonably close fit for the QC Mini with room for a small expression pedal, power supply, and cable(s)?
I just ordered a padded case from Studio Slips specific for the QC Mini.
They make great protective clamshell cases. I bought their case for the FM9 and it’s high quality.
Nate is super helpful.
I got a Lykus HC-2710 from Amazon. That particular one is the perfect size for just the QC Mini, but they have bigger sizes that could probably also take the PSU and expression pedal.
I have a bunch of Nanuk (Canadian Pelican) modular inserts for cameras and other stuff and thought Id try to see what I could fit into one of the spare ones I had. This is the N-Cubik 13M. The footprint is about the right size to fit a full size QC. Inside I could fit - QC Mini, 18 ft braided TS, 10 foot TS, (2) long 25ft XLR cables, picks, power supply, USB-C cable, and lots of space left for other little items. I put in my Sennheiser HD650s in but could easily swap that out for a small expression pedal and put IEM’s in instead. This would slide into pretty much any ‘regular size’ backpack which is how I use it for camera gear. You can also pair it with a 13S and both fit perfectly into a 935 case if you needed for more stuff for a gig or more protection. QC Mini also fits into the 13S itself with lots of room for power supply, cables, etc. which is half the size of the 13M
Thanks for this. What all are you able to fit in? And what foam arrangement did you end up building? If you have the time, please post a pic!
Mine is sized literally just for the QC Mini and nothing else, but that was deliberate. They do a few other cases of other sizes that could add a PSU and things.
Thank you! That’s exactly what I’m looking for. Did you pluck some foam in the bottom for the power adapter as well?
No, it’s pretty much the exact height just of the QCM. I just throw my PSU in my guitar case.
