Capture via Line Out on a tube amp?
Hi everyone.
New to capturing and I’d like to capture my Laney Supercub 12. I don’t have a mic or a Load Box, however the amp has an FX loop, and the FX Send is also marked ‘Line Out’.
My question is, can I use the Line Out jack (NB, it’s not the Speaker Out, its very clearly marked ‘Line Out’) as the DI Out to plug in to the QC to make a capture?
From a look at the Laney manual, I think you should be okay.
On most tube amps, though, you MUST keep a cab (or loadbox) connected to provide load even when using the DI out, otherwise Very Bad Things can happen to your amp. I think the Supercub 12 is a combo so you should be fine (the internal cab is always connected), but if you have a head-only amp this is really important.
Yes you can. However you will only capture the preamp section of your combo, as it is the send output.
Ah, good point, thank you
