Capture Input as Input
Hi, is it possible use the “Capture Input” as “Input” in Performance Mode ?
This is because it would be more convenient for me to connect the jack from the side instead of from the top.
Thanks in advance.
No, it’s not possible, unless you want to make a feature request which would go in another section, but honestly I don’t see much point in it, I think the nano needs other, much more important modifications than this.
Thanks for your reply. I very much agree with you, there are highly needed upgrades.
I’m glad I could help. I wish they’d add at least one more effects block before the capture block, and the ability to use pedal captures in addition to the amplifier capture, or a master output volume per preset. I’d be happy with any of that, haha. Cheers!
Well, there is a feature request for this. Main purpose was to add the ability to add an FX loop but it may serve multiple purposes. So drive capture into amp capture and another FX block before an FX loop would make nano the most flexible capture player and NC could compete with HX Stomp for features.
