Hi
I’m trying to add a Ptich block at the begining of this preset: https://cloud.neuraldsp.com/cloud/p/c8926764-fc16-42f7-b497-8817407f6eda but all the options are not available: they are grayed out.
But why please?
Thanks
Hi
But why please?
Thanks
“John’s amp” is using all the DSP/CPU power. It is a very high-consumption block. You don’t have enough DSP power left to fit in another block. Since it’s an official NDSP preset it is probably as optimized as it can be, but I’ll see if I can shift a few things around to free up enough room. Chances are that preset is pretty much locked because of the amps’ CPU usage though
If you get rid of the compressor and modulation blocks on row one you can fit any pitch effect block there except the Minivoicer.
Thanks all for your inputs, I remove an unused block and was able to add my Pitch block
