Cannot use QC mini with amp and load box for gigs
I’m trying to connect my amp via load box to the QCM and use the IR loader for playing live. However, regardless of connections and signal levels, it doesn’t work.
Going guitar to QCM input 1, then output 3 to amp input (tried humbuster and normal TS cable), speaker out to Two Notes Reload 2 load box, Reload 2 line out to QCM input 2 (tried both XLR to XLR and XLR to TRS), then IR block and then outputs 1 and 2.
However, no audio comes out. Can confirm signal is hitting amp, load box and input 2…. But nothing out of the QCM final sends.
Anyone been able to get it working?
First thing- why such a convoluted setup where you’re going back into the QC? Why not just use an IR with the load box? You’re adding a bunch of latency with that setup. I guess unless you’re adding effects after the amp head in the QC. That would make sense. The reload also has an effects loop which might be what you want to use the QC with instead.
Can you post a photo of your preset. No way to say unless anyone can see that. Most likely is a simple routing issue. Assuming you have Input 2 selected as the input for a separate lane from the one you’re using for the amp/two notes.
