Bring Tallon Electric Noise Pedal to the QC
This pedal should definitely be added to the Quad Cortex…enough said
Welcome @kevinj209
Sick AF​:sign_of_the_horns:t3:
Pretty sure tho this sound can be made in QC.
If anybody has a tutorial on that that would be dope!
@kevinj209 Only found one for the Fractal platform, but they too use blocks so it kinda gets you in the ballpark. It’s not the same, but it inspired me to play around with the idea and made two presets for the cloud. For Bass, but drop tuned/extended range guitar works as well (depending on ones setup).
Bear in mind I like going over the top​:sweat_smile::
InterFearence I & II
Oh word! Can you send me your cloud so I can check those out?
As your message here on the web forum shows you’re texting via email (small envelope icon in the right corner of your message) I suppose you can’t see the two direct cloud links posted in my previous answer on the device you’re using?
The links on the web converts automatically in the message prompt to special link boxes.
Anyway, as the presets are new they’ll be just a few scrolls down on the cloud’s “Latest presets” roll out.
Keeping fingers crossed they sound fine in your setup​:crossed_fingers:t2:, yet in case they sound like total v​:face_vomiting:mit (well they’re supposed to sound sick, but you know what I mean​:wink:) you’ll have somekinda guideline/inspiration to work from.
Remember to build your own preset from the ground up in case you wanna post your experiments to the cloud, since a simple copy/pasta will still hold the OP signature to it. You can however copy/pasta the single blocks (which include the settings) from my grid to your own.
Oh okay gotcha that makes sense. Im totally new to this forum since the noise pedal would be totally sick to have it streamlined in one block. I’ll have to check those presets out! Ive heard that some of the knobs on the noise pedal use a ring mod sound and unfortunately the QC doesnt have a ring mod effect…
Got it, a single Tallon block would be cool, but since it’s in itself a multi effect it’s probably not going to happen. At least not in the near future. Plus it’s a quite limited use area and lotsa other “pressing” implementations are in the works.
As you mention Ring Modulation, I tried to work around it with a Phaser and Filter.
You can vote for Ring Mod here:
Not to detract from this request, but at some point we should be getting a Glitch block when the Misha Mansoor X plug-in gets released to the QC.
Oh yeah @DiffractionCircuit, completely forgot about that. … Or they do as with the Synth; a bypass; a release beforehand for all – to feed the “starving” hordes?:wink:
… Dreamin’:drooling_face::thought_balloon:
That’ll be so tight when they release that
