Hi. Want to create bass lines in my loops. Is there a bass simulator in the QC? If not, are there any basic tips for creating one? I’d imagine pitch shifting…which isn’t an effect I’ve explored.
I’ve seem some on the cloud.
You could use a pitch block and pitch down -12 semitones.
I recommend a bass player for you bass playing needs ![]()
jk but a lot of compression and pitch shifting and low pass will get you close
Bass players are more expensive than a preset, Danimae. ![]()
Tanks fer da tips, people. I downloaded a couple of presets before getting the last two suggestions. One of them sounded pretty good. I’ll check out the parameters and use both your suggestions to tweak it.
Old thread, but did you find a good solution for this? Looking for the same thing myself. Any particular presets you can recommend?
