(AUX IN) play music on your phone with USB, the sound is very broken
QC USB AUX IN BUGGY (YT LINK)
You can hear problems happening in 20 seconds and 1 minute and 20 seconds.
(I am not a native English speaker, so my English is very poor, so I am sorry that I made it difficult for you to read.)
Hello.
I’m one of the people who recently bought a quadcortex and has been using it well.
To practice with QC in the corner of the room, I tried to use the sound source while listening to it together in QC using the aux in function.
I knew that I could connect to my smartphone with just USB and use it as a normal AUX IN function.
So I was able to connect to my smartphone using a USB B to C cable and play the sound source easily.
When playing it for the first time, the sound source is immediately heard from QC without any problems.
However, after a few tens of seconds, the sound source is immediately broken and distorted, producing a strange sound.
And if you wait for a while again, the problem disappears, and the original sound comes back and the sound source is played intact.
Unfortunately, if you wait for another moment, the sound source will collapse again, repeating the aforementioned problem.
This is not just a problem for my smartphone.
I’ve tested every smartphone and tablet PC I have, but the same problem has occurred on all devices.
I even tested it with a cable other than the USB B to C cable I was originally using, and I tested it with a C-type adapter or a C-type hub for another USB B cable, but the same problem was repeated.
I’ve done everything I can to check without much trouble.
The sound source in question was also recorded and attached through the audio interface.
I would appreciate it if you could check and give me an answer on the solution or cause.
It’s a known problem with android devices and windows that neural has been unwilling to fix. They blame it on android and windows usb drivers, and recommend using ios/mac.
I really wish theyd sort it out, as i also wish i could use my android devices to play music through the cortex.
At the very least it’d be nice to have a setting to use one of the audio inputs as an aux in.
this could be a great feature request
I’m a new Cortex Mini user, and I’ve encountered the same issue. It seems the QC developers aren’t interested in fixing it.
