Audio interface suggestion for Quad Cortex
Hi, I need some help to choose the right audio interface for my QC.
First of all, yes, I need an AI because not only have I two studio monitors, but I also have a Luxman stereo amp that power 2 HIFI speaker plugged into my AI with an aux cable. In short, I can’t use my QC as THE interface.
I’ve been using a Scarlett 2i2 for a year with my QC and for 10 years with plug ins. I never had any issues with it, but I’ve heard these interface were bad and were coloring the sound. Also because I’m planning to soon add a subwoofer to my setup, this AI needs to go for one with more input in the back and possibly 2 headphone input as well.
As you can imagine, I can’t really try five different audio interfaces in a row, compare them and choose one so, the question is, which one will give me the most unfiltered, the best audio quality to render the QC at his best ?
I’m trying to stay under €500 is possible.
TLTR : which audio interface won’t ruin the sound of my Quad Cortex and give me the best audio rendering ? (under €500 lol)
I call BS on that one.
Audio interfaces have gotten so good over the past years that even a cheap one is nearly indistinguishable from a high end one when it comes to sound. So if you get a good budget one, like the Scarlett, you are fine.
But as always, sound is subjective and it matters what you hear. If I were you I would try out a high end one and directly compare it to your Scarlett. That’s the only way to really compare and make an informed decision.
Scarlett interfaces are pretty bad. The bus powered ones don’t have much power for the preamp itself, and they are cheaper pre’s that color/distort the sound to a degree whether you’re noticing it or not. They also are very prone to grounding issues because of being usb bus powered.
Ideally you should get an interface with its own separate power supply. Something like what the other user in here mentioned could be good. Once you get into the slightly higher tier than the garbage bus powered ones you should be pretty fine for recording the QC at a better quality.
This is all coming from experience with someone who has worked with mixing material from lots of artists using various interfaces on their own. I’ve shot out tons of these things.
I’ve used various usb powered interfaces for well over 10 years without ever encountering grounding issues while I know some who own UAD, Apollo und Neumann who struggle with it. But that’s obviously another topic.
Soundwise, I would bet you or anyone a lot of money you wouldn’t be able to tell different audio interfaces apart in a blind-test. If I had a lot of money and would bet…
You can absolutely see the way the waveform distorts (in a vocal track for example) that it most likely came from a bus powered interface that’s distorting the signal. It’s pretty easy to see and listen for. The big thing here is- don’t get the cheapest possible interface and then wonder why it doesn’t sound great.
There’s diminishing returns on audio gear for sure once you hit a certain price, but you’re absolutely in the low end with these 100 dollar bus powered interfaces that can barely power a preamp
RME Babyface Pro FS. Costs +700bucks. Bus powered. Works like a charm. Same with the Scarlett. But once again, different topic.
Also, any interface these days can easily power a preamp. And with the QC going in, it doesn’t even have to add much gain. So… I really don’t see the problem you are describing.
As I said, get a good budget one and you are good to go. Absolutely don’t go for a shitty 15 bucks one. But the Scarlett is a safe choice. Was used on some grammy award winning songs, wasn’t it?
Pay more if you want more, but don’t expect the sound to suddenly change drastically.
RME is in a different class. Kind of the exception to the rule of bus powered interfaces.
What about the 8i6, is it bus powered ? It has its own power supply
I mainly use a Scarlett 4i4 3rd Gen at home and never had any problems whatsoever with grounding regardless of if I use it with my MacBook or my windows desktop computer even connected to an USB hub it works perfectly fine. :person_shrugging:
Hi Mark. Lots of solid perspectives here. Having been a recording person for a very long time I have used and own a number of interfaces. None have been awful but I do prefer those with a Thunderbolt connection because of how Tb works internally compared to USB. However the UA Tb interfaces are outside your price range. I have a pair of Clarett 8 port interfaces and they sound great but have more latency with Logic than the UA units although they are fine with LUNA. In your price range I have students who have been very successful with the desktop interfaces from SSL. They also have excellent preamps. Re the subwoofer, I have no experience with any interface that has a subwoofer out. In my experience subs have always come either out of a power amp or a powered studio monitor will have a sub out on it. So I cannot help you in that regard
Cheers!
I have been using the QC as an audio interface. Am I doing it wrong?
For what it’s worth: I just upgraded to the 4th Gen of the Scarlett 4i4 and noticed that all 4th Gen scarletts aren’t bus powered anymore and instead come with a seperate power supply (except the solo).
Please do not buy an interface if it’s going to be dedicated for plugging in Quad Cortex, because Quad Cortex IS an audio interface - just plug it in your PC and you can record your guitars right away, without additional D/A → A/D conversion which is completely unnecessary
ive got the scarlett 18i20 3rd gen and its amazing with no problems at all for less than £500
7th row
Not only First :slight_smile:
