Audio glitch when using stomp in tap tempo
CorOS Version: 3.2.1
Describe your issue:
When in tap tempo mode and I press the corresponding footswitch assigned to a stomp, Gojira octave, assigned to F, the sound drops in volume and becomes hi-fi/harsh. Similar to playing an amp sim without an IR, but not quite as bad.
This patch is on a high gain amp with an IR, XLR’s out to studio monitors.
  1. Engage tap tempo
  2. Push the corresponding footswitch for the octave pedal while on the tap tempo screen
  3. Disengaging the stomp does not resolve the sound issue. I have to change presets to ‘reset’ the sound.
I expected this to happen:
When I do turn on the octave pedal it should engage like normal, or not activate at all. I don’t believe it’s meant to be activated on this screen because the footswitch is green for a tap tempo twist knob (F). So the ability to alter stomps should be hard blocked to avoid accidental sound issues. I stumbled on this issue but it could be problematic someone in a live performance.
  • I have tried this with momentary function, still occurs
  • I have tried this with latching function, still occurs
  • I have tried on different footswitch locations, A, B, C etc, still occurs
  • Tried other effects, Nolly OD, Nolly reverb, same issue
  • Tried non-plug-in based effects, and still occurs with stock QC effects
