Сasts, authorization, etc
Hello everyone! There are a number of questions, I hope you can tell me)
  1. after restarting the QC, you have to re-log in to the system in order to download anything, is that how it should be? QC does not save authorization?
  2. how do I delete what I chose in the app, but it didn’t fit me when listening? (delete in the app and on the QC)
  3. how to take a cast of amplifiers without the participation of the cabinet in the formation of sound?They say the heads have a preamp-out exit, is this it?
I apologize in advance if something is written wrong, I used a translator) Good day to all
  1. It is SUPPOSED to save the auth. There is a bug they are working to fix that requires you to sign in each time presently.
  2. Choose ‘delete all’ on the Cloud app or website. On the QC itself you’ll have to delete each individually from the Download folder it’s temporarily located in.
  3. You can use the Direct outputs for capturing if the amp has them, but remember tube amps must have a speaker or load box attached to avoid damage
  1. that is, to delete selectively in any way in the cloud?
  2. can you tell me a little more about what these outputs are, please? I haven’t worked with “heads” that much.
  1. I don’t think there is a way to delete individual captures or presets from the Cloud app or site, just the option to ‘delete all.’ Even doing that still leaves them on your QC in the downloads folder. From there, they can be deleted individually. It would be a helpful option if they’d add the ability to choose selectively.
  2. The Direct Outputs can vary a little depending on the amp head, and some don’t have them at all. Do you have a specific amp model you are working with? Would help for advising.
  1. I seem to have found such an opportunity in the web version
  2. not yet, I want to go to the points and shoot the sound of heads, I met the preamp-out output from behind, but I didn’t connect it, I’m still worried that something will break)
