Archetype: Plini Presets Thread
Here is a Fusion style lead tone i have been using. Mid Focused Lead 1.xml (4.8 KB)
I only use the middle amp, the rest is set stock.
It pairs well with coffee and some improv over this backing track:
trying these they sound great ,fab , thank you
these are dope! i use the crunch one a lot now. thanks!
Hi Steven I would like to share a preset for Archetype Plini but unfortunately I can’t
Hi guys I share this preset with you … you can see the video on my youtube channel to hear how it sounds. good music at allnico lead a savior.xml (4.8 KB)
Here’s what I’ve been using on the Plini
Been using my prs custom 24 with suhr ssh+/ssv pickups and i love the results.
Main Squeeze.xml (5.0 KB)
But I’ve also loved using the ML Sound Labs Freeman V30 w/57 and Zilla H75 w/121 ir’s
Some modern Periphery inspired tones. not too high gain
Juggernaut.xml (4.8 KB) Modern Mishap.xml (4.8 KB)
Does anyone have preset for classic rock or 80’s and 90’s rock era sound ?
Both are amazing, specially Modern Mishap. Thank you!
Here is some more tight modern metal presets. Including a lush, warm stereo (Pingpong delay on 0 time) cleanBig Lead.xml (4.9 KB) Ironcore.xml (4.9 KB) Modern Mishap.xml (4.9 KB) Stereo Clean.xml (4.9 KB)
Thanks a ton for these. I did a bit of modification and these are my current go to presets.
Dorado
Hi All
You probably know this, but i though it worth mention for clean/acoustic tone chasers. Try Plini’s experimental preset:
High Life (Acoustic)
some compression, clean amp, EQ with midds cut and highs boosted (interesting!), NO CAB(!), and full WET fast delay…
I highly recommend to try this preset and even try to turn the amp’s presence up.
also, for further tweaking possibilities, here is a great guitarist explaining how he is setting up Plini:
Long time I haven’t been here, and for my come back, here’s a little preset I made to match Paul Gilbert sound in Mr Big tune “Green Tinted Sixties Mind”. Enjoy !
Adjust the Comp Gain knob to find the balance between helping the tapping of the intro without adding too much sensitivity.
Mr Big - Green Tinted Mind.xml (4.9 KB)
Example : https://www.instagram.com/p/CAh8z2HhTHk
beautiful, universal Petrucci-style solo tone!
Hi :slight_smile: does anyone have any tips for a decent slap guitar tone? I am using an 8 string guitar in drop E. Any tips or preset shares are much appreciated.
That Stereo Clean… just super smooth
Hey guys, amazing presets here all around. Gave me great starting points to work with, really appreciate it.
So I thought I should give back and share some of my own presets I’ve created. Here’s a bunch of various presets I’ve made using it. However, some of them use custom IRs from ML Sound Lab, so I’m really not sure how they would translate to another computer.
Hope this helps someone :slight_smile:
High Gain Lead 3 Mids TIGHT.xml (4.9 KB) Clean Lead new 2 2.xml (4.9 KB) Dreamy Lead 1.xml (4.9 KB) Gilmour Shine.xml (4.9 KB) Mellow Lead 1 .xml (4.9 KB) abandoned clean.xml (5.0 KB) Periphery - Satellites 1 .xml (4.9 KB) Periphery - Satellites 2 lead.xml (4.9 KB) Periphery High Gain 2.xml (5.1 KB)
Thanks so much everyone, these are amazing! I love the Stereo Clean and the Satellites ones!
Here is my own low gain preset, hope this is helpful for someone :slight_smile:
Low Heat Setting.xml (4.8 KB)
