Archetype abasi crash on startup (macos)
when i launch archetype abasi standalone on my macbook pro, it wont open and instead crashes and gives this code:
Crashed Thread: 17 com.apple.audio.IOThread.client
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
Exception Codes: 0x0000000000000001, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process: exc handler [1671]
VM Region Info: 0 is not in any region. Bytes before following region: 4308733952
my other neural dsp plugins all launch and work fine, and archetype abasi worked a few days ago fine as well. today i plugged a new midi controller into my laptop for the first time but after that it still launched as normal, and then it stopped working while i was moving some preset files around and changing settings. the only thing i found online was to reset mic settings with “tccutil reset Microphone” but it didnt fix anything.
Any ideas or help would be greatly appreciated, thanks
Please email support@neuraldsp.com the team will be able to troubleshoot this and assist you.
